M1 Chip
Music Teacher
M1 Chip
I just purchased the new MacBook Air with M1 Chip. I was really hoping to download and use Audacity, but it said to contact developers. Did I not download the correct version, or is an update on its way?
Re: M1 Chip
Audacity 3 is coming, but I understood that 2.4.2 would work. Did you get your Audacity from here?
https://www.audacityteam.org/download/mac/
Music Teacher
Re: M1 Chip
Yay, 2.4.2 is perfect! I did 2.1.1 before. Thanks!!!
billw58
Re: M1 Chip
Audacity 2.1.1 was a 32-bit application so will not run on macOS Catalina and beyond. This is not an issue with the M1 chip.
-- Bill
