Playback is accelerated
Help for Audacity on macOS.
DantheMan
Post by DantheMan » Sun Feb 21, 2021 7:59 pm
When I record a track into Audacity the playback is accelerated by about10% -- what should be about 7min, 10 seconds, actually clocks in at 6 minutes 40 seconds. And the pitch is correspondingly a little higher. It's happened about 4 times consecutively. I've reloaded Audacity, with no change. I'm on a 6-year old MacBook Air with Catalina OS. Help! And thanks!
Re: Playback is accelerated
Post by steve » Mon Feb 22, 2021 10:47 am
Please take us through step by step to reproduce the problem.
jademan
Forum Crew
Post by jademan » Mon Feb 22, 2021 9:59 pm
So when I do the math, it turns out that the ratio of your recording lengths is exactly the same as the ratio between 44100Hz and 44800Hz, the two most popular Digital-to-Analog sample rates. So in Audacity, you will find the main project sample rate in the lower left-hand corner and in the Track Control Panel of each track.
I'm a windows guy but see here to check your device sample rates on Mac: https://manual.audacityteam.org/man/err ... acsettings
Preferably, all of these sample rates should match.
I hope this helps. :D
