Can not launch ffmpeg-win-2.2.2.exe - "The setup files are corrupted"
maderemark
Hello,
I've been trying to install the ffmpeg codec for my Windows 10 machine without success.
First, I clicked the ffmpeg-win-2.2.2.exe found at https://lame.buanzo.org/#lamewindl and it downloads to my computer.
I then click the ffmpeg-win-2.2.2.exe file on my computer and get this message: "The setup files are corrupted. Please obtain a new copy of the program."
I doubt that the file I am downloading is corrupted as no one else has reported the issue.
I have downloaded it multiple times (just in case it got corrupted during the download process) with the same result.
I have rebooted my computer and tried again - same result.
I have tried running the exe program with Audacity running and without it running - same result.
Any suggestions?
Thank you.
Any suggestions?
Thank you.
Re: Can not launch ffmpeg-win-2.2.2.exe - "The setup files are corrupted"
I agree that it's unlikely, but best to check.maderemark wrote: ↑Sun Feb 21, 2021 10:51 amI doubt that the file I am downloading is corrupted as no one else has reported the issue.
Use this web page to analyze your copy of the "ffmpeg-win-2.2.2.exe" file:
https://md5file.com/calculator
The "SHA256" result should be:
abf3eee0c2556f6efa0d4446df7244778a61d6c3c339a4ecabaccdd85568e4e8
maderemark
Here's the result I got for SHA-256:
231122905d520e17391f62c9d5421b352c605e35e6c5675eec0bcc9fc0d760e2 (see screenshot)
Definitely not the same.
Would you mind downloading a copy of the exe file and see if you get the expected value or the one I got?
- Attachments
- Screenshot Of EXE Value.jpg (168.53 KiB) Viewed 391 times
I got the expected value:maderemark wrote: ↑Sun Feb 21, 2021 1:54 pmWould you mind downloading a copy of the exe file and see if you get the expected value or the one I got?
so your downloaded version is either damaged, or the wrong file.
When you download "ffmpeg-win-2.2.2.exe", ensure that you left click on the link to download.
maderemark
Yes, I was left-clicking on the exe file.
I just resolved the issue. I had to download the ffmpeg-win-2.2.2.exe to another computer, copy it to a thumb drive, copy it to the PC that said the setup files were corrupted and then it executed without any issues.
Thanks for your assistance, though. I appreciate it when someone else tries to help.
@maderemark Exact same as you. Did your ‘ I just resolved the issue. I had to download the ffmpeg-win-2.2.2.exe to another computer, copy it to a thumb drive, copy it to the PC that said the setup files were corrupted and then it executed without any issues’ and worked great.
maderemark
@rsimpkin
Interesting that I'm not the only one with this issue. I see you just joined today- probably because you encountered this problem as well.
I'm glad my post explaining how I resolved it helped you. I've decided that whenever I use these support forums for a problem and resolve it on my own - I always post my solution so that someone can benefit later. Glad to hear it helped someone else so quickly!
This is all very curious... I just downloaded the .exe file and the hash was OK and it seemed to run OK.maderemark wrote: ↑Sun Feb 21, 2021 11:28 pm@rsimpkin
