Chang recorded speeds
RampRat
Operating System: Windows 7
Post by RampRat » Sat Feb 20, 2021 5:04 pm
I have a reel to reel tape that is recorded at 1 7/8 speed, can I transfer the audio to Audacity in 3 3/4 speed then change the speed to 1 7/7 once it is in the computer?
Thank you, The Rat
DVDdoug
Forum Crew
Re: Chang recorded speeds
Post by DVDdoug » Sat Feb 20, 2021 5:15 pm
Yes! After recording: Effect -> Change Speed.
