Audacity and Steinberg UR22 mkII Microphone Issue
LichaDin
Operating System: Windows 7
Post by LichaDin » Fri Feb 19, 2021 9:17 pm
I am using a Windows 7 laptop and Audacity 2.4.1. When choosing the Input the option Line (Steinberg UR22) appears but for some reason it records the instrumental as I think it connects to the outpot. Everything else is plugged in correctly. There are no other options. I also choose the line as a default device but that makes no changes as only the Laptop microhpone appears in the option.
Please help my friends.
DVDdoug
Forum Crew
Re: Audacity and Steinberg UR22 mkII Microphone Issue
Post by DVDdoug » Fri Feb 19, 2021 11:01 pm
Make sure you haven't selected a "loopback" device.
jademan
Forum Crew
Post by jademan » Sat Feb 20, 2021 11:05 pm
Caveat. Steinberg has a vested interest in promoting its own ASIO USB protocol. Audacity does *not* ship with ASIO support for licensing reasons. So you may be better off with another audio program such as cakewalk or reaper.
Having said that, there are newer drivers available on the Steinberg site that you can try downloading to see if they correct the issue:
Here is the USB driver: https://www.steinberg.net/en/support/do ... river.html
and the latest firmware: https://www.steinberg.net/en/support/do ... 22mk2.html
I hope this helps. :D
