RMS Normalize
PaulGriggs
RMS Normalize
I have Audacity 2 2 2 and Windows 10. I need to download RMS Normalize as I need to edit an audio book. Can you help please.
Re: RMS Normalize
Audacity 2.4.2 has Loudness Normalization built in.
https://www.audacityteam.org/download/windows/
This is the long version of the instructions.
This is where to get ACX Check to test your work for ACX Compliance.
https://wiki.audacityteam.org/wiki/Nyqu ... #ACX_Check
And this is about what it looks like when you succeed.
Fair warning, you still have to be able to read out load. ACX Check only simulates the technical test and you still have to pass the human theatrical test. We can't do that one in software.
Re: RMS Normalize
Update to Audacity 2.4.2 and use "Loudness Normalization" with "RMS" selected as the type of normalization (See: https://manual.audacityteam.org/man/lou ... ation.html)
Audacity 2.4.2 is available via the Audacity website: https://www.audacityteam.org/download/windows/
