Align a Drum beat track to a click track
floatingboater
Hi, on a multi track recording I need to adjust a drums track to fit a click track. Firstly, I'm not a good drummer so some of the beats are noticeably out of alignment with the click track. I've tried selecting the drum track and cutting small sections out but it also cuts the same parts of the other tracks which i want untouched. I can't find a help or tutorial for it, can anyone help please? Thanks.
floatingboater
Re: Align a Drum beat track to a click track
Oh, and I don't mean the "Time Shift" facility, i would like to cut and/or add small individual pieces in between some of the drum beats to match the clicks. Thanks.
Make me a drummer?
We need you perform a song. It's in 7/8 time. Syncopated.
I think that's Punch-In. Select the track so the others aren't affected and go.
viewtopic.php?f=42&t=71556
Post back how it went.
1. Ensure that "Sync Lock" is NOT enabled (bottom of "Tracks" menu).floatingboater wrote: ↑Thu Feb 18, 2021 11:42 amit also cuts the same parts of the other tracks which i want untouched.
2. Ensure that you ONLY select the track that you want to edit (See: https://manual.audacityteam.org/man/aud ... ction.html)
floatingboater
Koz, thank you. I can see how it would add to the track but I can't understand how to take something away. Dare I say Just Cut (and not paste?) I.E., If my drum beat is a fraction late i would need to cut a piece out to the left of the drum beat, or am I missing something?
floatingboater
Thank you Steve that works a treat. Saved me a lot of re-recording.steve wrote: ↑Fri Feb 19, 2021 12:37 pm1. Ensure that "Sync Lock" is NOT enabled (bottom of "Tracks" menu).floatingboater wrote: ↑Thu Feb 18, 2021 11:42 amit also cuts the same parts of the other tracks which i want untouched.
Which fixed it? 1 or 2?
