How To Record Correctly
AndyTheAstronomer
Post by AndyTheAstronomer » Tue Feb 16, 2021 1:00 pm
Windows 10, Audacity 2.4.2
Hello, I wonder if anybody can help me.
I have a track recorded from line input. I wish to record a second track over it. So I create a new track, and start recording into it. I can hear the first track while recording, but the problem is that the second track records the first track as well as recording the second track. So I end up with the first track twice, which is not what I want.
So my goal is to play the first track and record the second on top, without the first also being recorded on the second track. Obviously I can mute the first track, but then I can't hear it.
Record/transport options are set to "overdub" .
I should be grateful for any help. It's probably something simple I don't know about Audacity (I hope not: I've been using it for years!)
Many thansk
Andy.
Re: How To Record Correctly
Post by steve » Tue Feb 16, 2021 1:09 pm
It is not necessary to manually create a new track. You can just press "Shift + Record button" or "Shift + R" to start recording to a new track.
Set the "recording device" in the Device Toolbar to the actual device that you wish to record from (for example, your microphone).
AndyTheAstronomer
Post by AndyTheAstronomer » Tue Feb 16, 2021 1:15 pm
Thanks Steve. That solved it! For some reason the record input had changed to "speakers" without me noticing.
I thought it odd, as I had not noticed it happening before!
Many thanks!
Andy
Post by steve » Tue Feb 16, 2021 1:31 pm
One possibility: Conferencing apps (such as Skype / Zoom) have a habit of changing the sound settings, which in turn can affect Audacity.
