Cannot Load DeEsser.ny into Audacity 2.4.2
Help for Audacity on macOS.
Chelsea
Post by Chelsea » Mon Feb 15, 2021 6:05 am
Hello All,
I am using Mac OS Big Sur 11.2.1 and Audacity 2.4.2
I have downloaded a DeEsser plugin I found reviewed on the Audacity forums, but it does not show up in the options when I go to the manage plugins menu on Audacity. Please advise. Thanks:)
Re: Cannot Load DeEsser.ny into Audacity 2.4.2
Post by steve » Mon Feb 15, 2021 10:59 am
The DeEsser plugin is a "Nyquist plug-in". Installation instructions for macOS are here: https://manual.audacityteam.org/man/ins ... st_install
