Changing 16 bit to 24 bit
Eddie 713
Post by Eddie 713 » Sat Feb 13, 2021 7:49 pm
I want to change a 16 bit mono track to 24 bit to share with dropbox. Any help is greatly appreciated. Thanks! 🤘
DVDdoug
Forum Crew
Re: Changing 16 bit to 24 bit
Post by DVDdoug » Sat Feb 13, 2021 8:12 pm
When you export, the Window where you enter the file name and type of file also has options for bit depth, etc., depending on file type.
But why??? You don't automatically get higher resolution or better sound by converting to a higher resolution format. You just make the file bigger.
Eddie 713
Post by Eddie 713 » Sat Feb 13, 2021 9:41 pm
So the bit rate matches the other files of the recording. Thank you for the info! I'm new to audacity. How do I export the file?
Post by steve » Sat Feb 13, 2021 10:55 pm
By default, Audacity works in 32-bit float format. It is very highly recommended that you retain this default.
To export as 24-bit wav, select "File menu > Export > Export as WAV", and then set "Encoding" to "Signed 24-bit PCM".
Eddie 713
Post by Eddie 713 » Sun Feb 14, 2021 12:21 am
Thank you!
