opsys win xy pro, serv pac 2
I have use the windows control panel to uninstall 1.3.7
deleted the audacity folder in both program files and un application data audacity
when i try to run audacitry it gives me the following error
The application has failed to start because the application configuration is incorrect.
Reinstalling the application may fix this problem
i tried to do the reinstall but still did not run
thanks for any help
1.3.8 installation problem
emsteel123
waxcylinder
Re: 1.3.8 installation problem
I upgraded from 1.3.7 to 1.3.8 on a Vista machine in the last couple of hours successfully.
Here is my sequence:
Use Windows control panel to uninstall 1.3.7
The Audacity folder in C Program files was left behind, but most of its contents were gone. All that was left in that folder was a notch filter I had added to 1.3.7 that is not formally part of it. And I think lame_enc.dll was left behind.
I moved the notch filter and lame_enc.dll to a temp directory and installed 1.3.8.
After the install, I copied the notch filter back to the plugins directory of the new installation, and I copied lame_enc.dll back into the Audacity folder of the new installation.
You might uninstall again and inspect what is left behind, move that stuff to a temp directory, reinstall, and if necessary copy that stuff back.
