Can't record from the second input of my audio interface
muinao123
Post by muinao123 » Thu Feb 11, 2021 8:54 pm
I can't record from the second XLR input of my audio interface. I've tried changing the options in the 'preferences' in edit menu. On my second laptop it's working fine. Pliz help
DVDdoug
Forum Crew
Re: Can't record from the second input of my audio interface
Post by DVDdoug » Thu Feb 11, 2021 11:04 pm
Make sure that both Windows and Audacity are configured for 2-channel stereo. [Corrected - Thanks, Jademan!]
jademan
Forum Crew
Post by jademan » Fri Feb 12, 2021 3:15 pm
or here: https://manual.audacityteam.org/man/faq ... _stereo.3F
muinao123
Post by muinao123 » Sun Feb 14, 2021 11:46 am
Both audacity and windows are set at 2 channels stereo. I have checked the recording meter on the sound dialog box in windows. The meter jumps green when I talk on the microphone but it appears that audacity doesn't detect. I'm using Windows 10 and audacity 2.1.3
Post by kozikowski » Sun Feb 14, 2021 4:27 pm
Macs have a thing called Audio MIDI Setup where you can mess with sound channels. I'm not a Windows elf.
Screen Shot 2021-02-14 at 8.19.46 AM.png (70.2 KiB) Viewed 80 times
Which chat program are you using? Skype, Zoom, WeChat, etc? They all take over the sound services on your machine. Have you ever used one or more of these on this machine?
Do a clean shutdown. Shift+Shutdown > Wait > Start. Not Restart and not regular Shutdown. While its coming back up, Do Not let anything else start.
If it's still reluctant, disconnect the network or shut down the WiFi and try it again. See what complains.
I only know of one outright refusal of service. Audacity historically doesn't do anything to the input signal. Sometimes if you cross Stereo/Mono by accident, Audacity will refuse the connection—full stop. There is no "only recording the left channel." That's very much something Zoom might pull.
