How to make Audacity record in loop
Hammond542
Operating System: Windows 7
Post by Hammond542 » Wed Feb 10, 2021 7:22 am
I know how to loop PLAY (with shift+space after defining a region), but i can't find how to record while looping the region.
Precisely: I want to record multiple versions of the same vocal line in a single session, without declaring a new navyarmyccutrack everytime.
Is it even possible? If not I might change software.
Re: How to make Audacity record in loop
Post by steve » Wed Feb 10, 2021 10:05 am
Audacity can't record in a loop, though you can of course record the same thing over and over on one track.
jademan
Forum Crew
Post by jademan » Thu Feb 11, 2021 12:16 pm
How many times will you be recording over the loop ?
You can always just duplicate the audio manually in Audacity. This is fairly easy to do:
For example, if your entire track consists of the audio you wish to loop:
1) Use Ctrl-A to select All audio (here, were planning to loop all audio).
2) Click the Skip-to-End, then Ctrl-V to copy the original audio.
3) Repeat step 2 a total of 7 times.
4) Use mix and render to remove split marks.
5) Repeat steps 1 - 4 a couple of times.
If you start out with 1 second of audio to loop, one pass will give you 8 seconds, two passes will give you 64 seconds (about a minute). Three passes will give you 8 minutes, and Four passes will give you an hour.
I hope this helps. :D
