Cannot record PC sounds using Audacity 2.4.2
Docsteve
Post by Docsteve » Wed Feb 10, 2021 12:22 am
Hello all,
I am having a new issue with the recording of sound on my Windows 10 PC. If I am playing a home filming item or trying to record a conference call, the audio from my PC will not record.
It used to work perfectly when I last did this around 6 months ago, but I can only assume that a Windows update has been applied, as nothing else has changed.
It appears as though my Audacity v2.4.2 is only able to record from microphones and no longer from PC resident applications etc. I have searched around online and have tried all of the various fixes with the Stereo Mix device etc... but no fix.
Has anyone else experienced this and is there a solution?
Many thanks.
Eljustel
Re: Cannot record PC sounds using Audacity 2.4.2
Post by Eljustel » Wed Feb 10, 2021 12:39 am
I'm also in Audacity 2.4.2. I'm not recording on my Windows PC but I am trying to listen to an interview I recorded on my iPhone and need to get into the files and sort them out. I have been trying with the first one which I saved as WAV - I had read that only WAV or MP4 would be accepted on my Win10 by Audacity. I've opened the file, but the audio doesn't work and I'm running out of trying to find out why.
Hopefully there will be some positive responses!
Post by kozikowski » Wed Feb 10, 2021 12:39 am
There is one other odd possibility.
Since nobody can record conference calls, what you had before was broken.
Not all machines have Stereo Mix or can get it to work. Have you been through the Audacity Windows instructions?
https://manual.audacityteam.org/man/tut ... puter.html
There is a setup before you do that.
Do a Clean Shutdown of Windows. Shift+Shutdown. Wait, and then start. Do Not let anything else start. Let it settle and then see if you can get recording to work. Particularly with Skype, Zoom, etc, when they are running, you are not the primary user of the machine. Zoom is. Zoom (etc) likes to take over Windows sound services—and there is no option.
Sometimes a Windows update will cause troubles and even sometimes your virus protection software, but that's usually nothing like the trouble conferencing can cause.
Post by kozikowski » Wed Feb 10, 2021 12:52 am
How and with which app? Actual iPhone? Real Live Two People at a Table? Other?
Music Memo uses a really terrific sound file format. It's so terrific that nobody else can open them. How did you transfer the files out of the iPhone? Or better yet, how did you make the WAV files?
As I search.... As of March 2021, Music Memos is no longer supported for new users.
If you look away for a second everything changes.
Post by kozikowski » Wed Feb 10, 2021 1:01 am
Do you get an error when you open them in Audacity? Are they the right duration but just silent?
Select the track with the button on the left. Effect > Amplify > OK.
What happened?
Eljustel
Post by Eljustel » Wed Feb 10, 2021 1:05 am
I have Audacity on the iPhone which I used for a two-person interview. That only records and saves it as a .m4a file. I had to upload it to Cloud, then download it to my Win10 PC to Switch and convert it to .WAV. Audacity uploaded it on the PC but I get an error message: "Error opening sound device. Try changing the audio host, project device and the project sample rate." I clicked on the Help link and ended up in the manual, which I have tried to read through. I have checked the Settings for audio but can't find any problems. I use my earphones and it works on other stuff (I watch some ABC iView) but not on Audacity. Audacity was recommended for the Griffith University journalists course I am now on, but I am stuck.
Eljustel
Post by Eljustel » Wed Feb 10, 2021 1:17 am
Photo attached of issues on my Audacity.
Missing info.jpg (124.95 KiB) Viewed 181 times
Post by kozikowski » Wed Feb 10, 2021 2:32 am
Really? Audacity on the iPhone? I didn't think that existed. Is it a special build? Where did you get it from?
Is there playback sound from any other application on the computer? Are you plugging headphones into a soundcard behind a desktop machine?
Audacity usually displays the default internal soundcard from a PC. If you go into the Windows control panels (speaker symbol on the lower right), which sound devices are listed?
It's best to stick with generic, plain sound standards until you get running. 44100, 16-bit, stereo or mono. The rate should appear in the lower left of audacity.
Screen Shot 2021-02-09 at 18.29.52.png (12.93 KiB) Viewed 177 times
If you get these settings far enough off, Audacity may not find your interfaces or devices.
Eljustel
Post by Eljustel » Wed Feb 10, 2021 6:37 am
It's an app. My iPhone is v.11, model number MWLU2X/A. The warranty doesn't expire for 2 days (12 Feb). I downloaded Audacity from Apple app store. On my Windows PC I get playback sound, like when I watched ABC's iView - a couple of weeks ago I watched 6 editions of a story. I plug my headphones into the front of my PC - just a round plug hole with a picture of headphones. Yes, they work. The speaker icon says headphones presently at 35%. 44100 is the same as my Audacity. However, right now I can't use the headphones to listen to Audacity.
Post by steve » Wed Feb 10, 2021 9:36 am
That's not an official version of Audacity.
There are plans to put Audacity in Apple Store (and Windows Store) but we have not done so yet. If you wish to continue using that version you must contact the supplier for support because we have no information about any modifications that they have made.
I would recommend removing that version and installing the official version which is available via the Audacity website: https://www.audacityteam.org/download/mac/
Also, if you have a link for the Apple Store version, please let us know and I'll pass it on to the appropriate person that deals with such things.
