Splitting up tracks on recorded LP
geoffhld
Post by geoffhld » Sun Feb 07, 2021 8:01 pm
I am new to Audacity. Need some help with dividing up recorded LP tracks into individual songs
I reviewed the Tutorial 'Splitting a recording into separate tracks' Found it a little vague.
Windows 10 Audacity Version 2.4.2
DVDdoug
Forum Crew
Re: Splitting up tracks on recorded LP
Post by DVDdoug » Sun Feb 07, 2021 9:10 pm
You can simply select/highlight one song at a time and then use File -> Export -> Export Selected Audio to export the selected song. (Then I sometimes import one song at a time to trim the silence at the beginning & end.)
jademan
Forum Crew
Post by jademan » Mon Feb 08, 2021 8:31 pm
Also see: Sample workflow for LP digitization
I hope this helps. :D
