trying to adjust latency with usb mic and scarlett
sdwilcox
Post by sdwilcox » Sun Feb 07, 2021 7:02 pm
Hi -
I am recording audiobooks with my setup and would like to start using the punch and roll feature with Audacity. I have Windows 10 and the newest version of Audacity. I'm using a Marantz cardioid condenser mic (USB) and a Scarlett solo.
As it stands right now, there is a latency issue when the recording starts again, a little burst of sound.
I never did tune the latency because I wasn't sure how to do it with my setup. I don't think the standard audio loopback cable will work here.
Help anyone?
Thanks!
- Stacy
Re: trying to adjust latency with usb mic and scarlett
Post by kozikowski » Mon Feb 08, 2021 12:39 am
I suspect we're talking about two different microphones.
This one?
Screen Shot 2021-02-07 at 4.30.46 PM.png (44.29 KiB) Viewed 122 times
Sure. Plug that straight into your Solo with an XLR cable...
...and plug your wired headphones into the Solo. You might need an adapter.
Punch Direct Monitor so you can hear yourself, set up the recording latency in Audacity and go.
Piece of cake.
sdwilcox
Post by sdwilcox » Wed Feb 10, 2021 5:24 pm
Thanks, Koz.
That is, I believe, the mic I have, and I have everything plugged in as shown.
It's the "set up the recording latency in Audacity" that I am unsure how to do... ?
- Stacy
jademan
Forum Crew
Post by jademan » Thu Feb 11, 2021 8:58 pm
- Stacy
So apparently you have the Marantz Pro MPM1000, and *not* the Marantz Pro MPM1000U (USB) version. You are using the 3-pin to 3-pin XLR cable that koz has pictured to connect your Focusrite Scarlett Solo (3rd Gen) USB Audio Interface.
And you have your headphones plugged into the Scarlett and the Scarlett plugged into the PC.
I am thinking that you need to turn OFF Direct Monitor then hold your headphones to your microphone when you do your latency test: https://manual.audacityteam.org/man/latency_test.html
Then after you set your latency, turn Direct Monitor back ON.
But you have already figured all of this out for yourself. :)
I hope this helps. :D
