Copy and apply edit settings between clips (Mircrosoft 10, Audacit 2.4.2)
Juls11
Post by Juls11 » Sun Feb 07, 2021 5:04 pm
Hi!
Is there a way to copy and apply edit settings between sections of a recording that are in the same, or different, recording? THANKS.
ENJOY your day!
Juls11
Re: Copy and apply edit settings between clips (Mircrosoft 10, Audacit 2.4.2)
Post by steve » Sun Feb 07, 2021 5:26 pm
What settings do you want to copy?
jademan
Forum Crew
Post by jademan » Mon Feb 08, 2021 3:41 pm
Hi!
ENJOY your day!
Juls11
:?: settings :?: Not sure what you want here.
See here to cut and paste audio: https://manual.audacityteam.org/man/edi ... icate.html
I hope this helps. :D
