Will not record
Help for Audacity on macOS.
Meade
Operating System: macOS 10.14 Mojave
Will not record
Post by Meade » Sun Feb 07, 2021 6:39 am
I'm using macOS 10.14.6 and Audacity 2.4.2 It will not record from built-in microphone or Soundflower (2 ch) Quick Time Player records from built-in microphone. I wish to use Audacity to record an audio file playing with Quick Time Player. I have uninstalled and reinstalled Audacity two times with no improvement. I have used Audacity in the past with older versions with great success. :( Any help is appreciated.
Re: Will not record
Post by steve » Sun Feb 07, 2021 10:52 am
Why not just Import the file into Audacity? (See: https://manual.audacityteam.org/man/imp ... audio.html)
Meade
Re: Will not record
Post by Meade » Sun Feb 07, 2021 3:09 pm
I have imported it into Autacity and it plays just fine in Audacity. Can I edit it? I ALSO NEED TO RECORD FROM MICROPHONE. It will not record from Microphone also.
Re: Will not record
Post by steve » Sun Feb 07, 2021 3:26 pm
Can I edit it?
See here: https://manual.audacityteam.org/man/edit.html
Re: Will not record
Post by steve » Sun Feb 07, 2021 3:27 pm
What happens when you try to record from the built-in microphone?
Have you given Audacity permission to use the microphone? (in the Mac "Privacy" settings)
Meade
Re: Will not record from Soundflower (2ch)
Post by Meade » Mon Feb 08, 2021 4:25 am
With your advice it now records from internal microphone. It still will not record using Soundflower (2ch). Other people have reported problems with Soundflower. Can you recommend an alternative to Soundflower for recording an audio file playing in the mac?
Re: Will not record
Post by steve » Mon Feb 08, 2021 10:40 am
Fwiw, Soundflower works for me, but yes you are right, a lot of people have reported problems with Soundflower.
The original version of Soundflower is obsolete and no longer maintained, but there is a later version available from here: https://github.com/mattingalls/Soundflower (Read the "ReadMe.md " in the lower half of that page).
There's an app called "Black Hole", but I've never used that.
Meade
Re: Will not record
Post by Meade » Mon Feb 08, 2021 3:01 pm
Thank you for your help. The later version of Soundflower corrected the record issue. All is well.
