unrecoverable error....
Help for Audacity on macOS.
pauldoran
Post by pauldoran » Sat Feb 06, 2021 11:44 am
Latest update of Big Sur 11.2.
Audacity 2.4.2
Since the latest Big Sur update a couple of days ago Audacity won't open at all having worked perfectly (more or less) for the last few months.
Audacity Start Up failure.
Unrecoverable error has occurred during start up.
I desperately need to get Audacity up and running asap as I've deadlines to meet. Can anyone help? I reinstalled Audacity just in case but nothing.
Thanks.
Re: unrecoverable error....
Post by steve » Sat Feb 06, 2021 12:01 pm
That sounds like it could be related to this bug: https://www.timesnownews.com/technology ... xes/682694
Do you have a Time Machine backup made before that update?
pauldoran
Post by pauldoran » Sat Feb 06, 2021 5:23 pm
Sadly no. And thanks for the link.
Post by steve » Sat Feb 06, 2021 11:58 pm
You could try doing a manual reset of Audacity.
Go to the folder
Code: Select all
~/Library/Application Support/audacity/
(where "~/" means your home folder)
and delete the three files:
  • audacity.cfg
  • pluginregistry.cfg
  • pluginsettings.cfg
On next launch you should see the Audacity welcome screen.
