Copy selection to new file
Questions, discussion and recipes for scripting and batch processing in Audacity.
See also the "Scripting" section of the Audacity manual.
cantgetnosleep
Post by cantgetnosleep » Fri Feb 05, 2021 12:38 am
Hello,
I'm an trying to write a very simple script. It was working previously, but for some reason has stopped working. I am on PopOS (Ubuntu, more or less) 20.10. The script has three steps:
1. copy
2. new
3. paste
This script worked previously but now no longer works. It copies and creates a new file, but the paste doesn't do anything.
Any ideas?
Thanks,
Andrew
Re: Copy selection to new file
Post by steve » Fri Feb 05, 2021 1:07 am
"New" creates a new project, but macro scripts can only act on the current project.
If you intend to paste to a new track, try this:
Code: Select all
Copy:
NewMonoTrack:
Paste:
cantgetnosleep
Post by cantgetnosleep » Sat Feb 27, 2021 8:27 pm
Thanks. I don't want a new track. I want it in a different project or file. This used to work. Is there no way to copy the selection of a new project/file?
Post by steve » Sat Feb 27, 2021 9:35 pm
Not with a macro, and as far as I'm aware that has never been possible in Audacity. Why would you want to do that?
cantgetnosleep
Post by cantgetnosleep » Wed Mar 10, 2021 5:38 pm
I used it all the time. Every other audio editing software I've used had this as a built-in key command. This macro actually previously worked fine in Audacity. It stopped working in one of the more recent updates.
Andrew
Post by steve » Thu Mar 11, 2021 9:58 am
I must be misunderstanding what you mean, because Audacity has never had that ability and I've never seen it in any other audio software.
If you have three projects open, (let's call them "A, B, and C") and you run the macro in project "A", what exactly "should" happen?
