Can't exit zoom
Sereia
Can't exit zoom
Post by Sereia » Thu Feb 04, 2021 8:28 pm
I've only used Audacity a few times, so I am very much a novice. I believe that I have version 2.4.2 but I am not sure how to check and since I am in the middle of recording, I don't want to lose my work by exiting. I downloaded the latest version in November. I use Windows 10. The purpose of my recording is read a newsletter which will be broadcast for those who cannot read, so I only need to know basic recording information. Here's the problem:
After recording 90 minutes of the newsletter, and very close to finishing, I made a mistake and clicked pause as is usual, so that I could highlight the error, delete it, and re-record. However, I hit the zoom button by accident. This has happened before and I've been able to hit escape and return to recording, but now I can't. The Audacity manual says to use the escape key, so I've tried this three different ways: alone, while holding down a left click, and while holding down a right click. None of these attempts have worked. When I move my cursor to try to highlight a section of the recording so as to listen to it or delete it, the cursor appears as a zoom key rather than a regular cursor, and it highlights a section with dotted lines which then zoom in.
My recording should be broadcast as soon as possible, so I'd really appreciate an expert's advice. My greatest fear is that whatever I try to do to fix the problem will stop the recording and make me lose the 90 minutes of recording which took 4+ hours to record. I don't want to have to do it all over again if possible. Thanks in advance for any help!
Re: Can't exit zoom
Post by steve » Fri Feb 05, 2021 12:12 am
You may have inadvertently switched to the "Zoom Tool" (See: https://manual.audacityteam.org/man/zoom_tool.html)
To get back to the normal "Selection Tool", press the "F1" key (See: https://manual.audacityteam.org/man/selection_tool.html)
Sereia
Re: Can't exit zoom
Post by Sereia » Fri Feb 05, 2021 4:54 pm
When I click F1, a new window opens which links to how to access help in Windows 10. Nothing changes in Audacity. I am still in the zoom toolbox.
Re: Can't exit zoom
Post by steve » Fri Feb 05, 2021 6:50 pm
Then click on the "selection Tool" button.
Sereia
Re: Can't exit zoom
Post by Sereia » Fri Feb 05, 2021 7:16 pm
That worked! Funny, I thought I had already tried that, but clearly not. Thank you!!
jademan
Forum Crew
Re: Can't exit zoom
Post by jademan » Sun Feb 07, 2021 1:28 am
It makes one think that a second click on an erroneous tool should revert back to "Selection." Just sayin'. :D
Re: Can't exit zoom
Post by steve » Sun Feb 07, 2021 10:16 am
It doesn't make me think that.
There are 6 "Tools" to choose from. The behaviour that's "obvious" to me is that when you click on one of the 6 buttons, that one is selected.
