add second song to the first first so they play continuous
Help for Audacity on macOS.
johnnie
Post by johnnie » Thu Feb 04, 2021 8:01 pm
Hello I wish to add a second song to the first so they play continuous the songs are already two MP3 files
Thank you
Johnnie
Re: add second song to the first first so they play continuous
Post by steve » Thu Feb 04, 2021 8:07 pm
Are you importing the songs from audio files, or recording them?
johnnie
Post by johnnie » Thu Feb 04, 2021 8:10 pm
Sorry Steve I edited my post just as you was answering. Two mp3 files
Post by steve » Thu Feb 04, 2021 8:19 pm
1. Import both files
2. Zoom out so that you can see sufficient empty space beyond the end of the tracks (see: https://manual.audacityteam.org/man/zooming.html)
3. Drag one file to the right with the Time Shift Tool.
There's a slightly quicker way using "Align Tracks", but I'd recommend doing it manually first. (https://manual.audacityteam.org/man/tra ... racks.html)
johnnie
Post by johnnie » Thu Feb 04, 2021 8:24 pm
Thank you Steve for your lightning helpful reply.
Regards
Johnnie
