enhance sound
Help for Audacity on macOS.
johnnie
enhance sound
Post by johnnie » Thu Feb 04, 2021 5:43 pm
Hello I am fairly new to Audacity and I am pretty basic on using it.
I have a cassette of a brass band and also some vocals. The recordings were made just using a cassette recorder and I am wondering if there is a way to enhance the overall sound plus solo's.
Regards
Johnnie
Re: enhance sound
Post by steve » Thu Feb 04, 2021 6:29 pm
Noise Reduction (don't over do it or it will sound weird): https://manual.audacityteam.org/man/noi ... ction.html
Graphic EQ (adjust to taste): https://manual.audacityteam.org/man/graphic_eq.html
Normalize (apply just before exporting your finished audio file): https://manual.audacityteam.org/man/normalize.html
johnnie
Re: enhance sound
Post by johnnie » Thu Feb 04, 2021 7:45 pm
Thank you very much
Regards
Johnnie
