OS: Windows 10
Audacity Version: 2.4.2
Every time I open Audacity, I see that the Bass and Treble window has the bass level and volume raised at maximum. When I try to reset it, it lasts the whole session, then it goes back to the bass and volume levels being maxed when I reopen Audacity. Why is it doing that?
Bass and Treble thing
MickeyBlack
- Attachments
- bug.png (71.01 KiB) Viewed 122 times
Re: Bass and Treble thing
I don't know... For me, it seems to remember the last setting so if I set both sliders to zero, they are at zero next time I open Audacity and then open the Bass & Treble effect.
The value gets saved when you click "Apply". Generate a tone, set your Bass and Treble controls, then click Apply. Exit Audacity and return. Your setting should be as they were when you clicked Apply.MickeyBlack wrote: ↑Wed Feb 03, 2021 11:03 pmOS: Windows 10
I hope this helps.
MickeyBlack
It worked. Thank you!
You are welcome!
