Find the makers
Help for Audacity on macOS.
Rush
Operating System: macOS 10.11 El Capitan
Find the makers
Post by Rush » Wed Feb 03, 2021 4:15 pm
Hi, I would like to know where I can find the makers to select a portion of audio and copy it, delete it etc. On Bias Peak you can put a MARKER in a precise point and another afterwards and then select the track from marke to marker. How do you do it on Audacity? Thank you
:D :D :D :D :D
billw58
Re: Find the makers
Post by billw58 » Wed Feb 03, 2021 4:26 pm
Audacity has labels.
You can also use clips to mark audio.
-- Bill
Trebor
Re: Find the makers
Post by Trebor » Wed Feb 03, 2021 4:30 pm
Can split the selected portion, or add a label track.
