Add rhythm track to existing project
Re: Add rhythm track to existing project
Post by steve » Thu Feb 18, 2021 12:39 pm
floatingboater wrote:
Thu Feb 18, 2021 11:48 am
Steve, apologies for delay, I'm using Audacity 2.4.2, windows 10 pro.
These steps should work: viewtopic.php?p=415700#p415700
If not, do: "Tools menu > Reset Configuration" first, and then try again.
floatingboater
Post by floatingboater » Sat Feb 20, 2021 9:16 am
Success! Thank you Steve, reset configuration worked. Many thanks. :D
