Add rhythm track to existing project
floatingboater
Post by floatingboater » Wed Feb 03, 2021 8:22 am
Hi, Is there a way to add a rhythm track to an existing project? I originally used an external click track so i know the exact BPM. I've tried generating a rhythm track but it is being placed at the front of track 1 instead of alongside as a new track. Thanks.
Re: Add rhythm track to existing project
Post by steve » Wed Feb 03, 2021 11:53 am
  1. Click on a track where you want the first beat to occur.
  2. Press "Enter" to toggle off the track selection (de-select the track that you clicked)
  3. "Generate menu > Rhythm Track"
floatingboater
Post by floatingboater » Wed Feb 03, 2021 5:53 pm
Thank you for that Steve. I followed it and it created the new click track but not alongside the existing song. The existing wave bars were pushed along so that the new click track played alone. when it ended the existing track resumed where I had started the new one. I could use the Time Shift Tool, Is that the way? Thanks.
Post by steve » Wed Feb 03, 2021 7:35 pm
Sounds like you missed out step 2.
floatingboater
Post by floatingboater » Thu Feb 04, 2021 9:30 am
Hi Steve, No i followed all the steps, and it did toggle off the selected track and created a new track. However on playback it starts without the new click track until it reaches the point i chose then plays the new click track alone. At the end it reverts back to playing the original recording minus the new click.
However I have found another way, Create a new click track. open existing project (opens in new window). Then cut and paste one into the other. Seemed to work OK.
jademan
Forum Crew
Post by jademan » Fri Feb 05, 2021 1:01 am
Hmm... OK, so try this:
1) Tracks > Add New > Mono Track
2) Click in newly created mono track where you want 1st beat.
3) Generate > Rhythm Track, etc.
I hope this helps. :D
floatingboater
Post by floatingboater » Mon Feb 08, 2021 8:50 am
Thanks Jademan but same result. It punches a hole in the original track when i tried it. Did it work for you?
Post by steve » Mon Feb 08, 2021 11:28 am
Which exact version of Audacity are you using? (look in "Help menu > About Audacity")
Which version of Windows?
jademan
Forum Crew
Post by jademan » Mon Feb 08, 2021 1:17 pm
Perfectly. (Also, added additional clarity to original post) :D
floatingboater
Post by floatingboater » Thu Feb 18, 2021 11:48 am
Steve, apologies for delay, I'm using Audacity 2.4.2, windows 10 pro.
