Using UR44 with Audacity on Mac
Help for Audacity on macOS.
piyushs
Post by piyushs » Wed Feb 03, 2021 1:55 am
I am trying to use UR44 with Audacity on Mac (Big Sur V11.0.1), however I can not get Audacity to recognize UR44. I have installed the driver for UR44 and the dspMixFx_UR44 application from Yamaha recognizes the box along with any input.
Also when I look under the preferences, UR44 shows up as a MIDI device and not a audio input/output device.
Not sure what I am doing wrong, any help will be appreciated.
Thanks
jademan
Forum Crew
Re: Using UR44 with Audacity on Mac
Post by jademan » Wed Feb 03, 2021 2:57 pm
Thanks
Windows guy here. I don't know why it is only showing up as a MIDI device. You should be able to use the UR44 with Audacity on Mac. See here: viewtopic.php?t=113716
Are you using Audacity 2.4.2 ? Does Audacity have permission to use the microphone ? See here: viewtopic.php?t=113466
I hope this helps. :D
