Audacity doesnt seem to be able to use my headset
DeadL1ght
Post by DeadL1ght » Tue Feb 02, 2021 4:36 pm
Version 2.4.2
So I just installed audacity, and am trying to record sounds that come from my computer. I am using USB -c headphones (not sure if that's an important factor)
so after installing it I followed these instructions https://www.wikihow.com/Record-Audio-on-a-PC and get the error "error opening recording device -9997 " incorrect sample rate"
as can be seen from the attachment the sample rate of my headset and audacity are the same.
thanks for the help :)
DVDdoug
Forum Crew
Re: Audacity doesnt seem to be able to use my headset
Post by DVDdoug » Tue Feb 02, 2021 5:11 pm
I assume "Speakers (XFI GAMER)" is your regular soundcard. Make sure you've selected the USB device.
I don't know if this will make a difference but try un-checking "Exclusive Mode".
jademan
Forum Crew
Post by jademan » Wed Feb 03, 2021 12:46 pm
Version 2.4.2
Also, If I am having problems with Windows WASAPI, I find I can sometimes get things to work with MME.
I hope this helps. :D
