Noise when the recording volume is at 0
andremax3635
Post by andremax3635 » Mon Feb 01, 2021 5:30 pm
Is it normal to have a noise when I set the microphone volume to 0 and amplify the audio at 50DB?
I'm a beginner in this world of audio, I looked elsewhere and found no answer.
link: https://soundcloud.com/andre-luiz-435281840/ruido
Re: Noise when the recording volume is at 0
Post by steve » Mon Feb 01, 2021 5:55 pm
Analog recordings always have some amount of background noise. When you amplify by 50 dB, it is to be expected that the recorded noise will get much louder.
Post by kozikowski » Mon Feb 01, 2021 6:02 pm
It's good to avoid extremes of volume correction.
What's the microphone and how is it connected?
andremax3635
Post by andremax3635 » Mon Feb 01, 2021 10:50 pm
Thanks for the answer.
Answering the question, it is connected to the 3.5mm input of a sound card, the strix soar.
Microphone is a boya cardioid by mm1
