LP side two track numbering to follow from side one
Help for Audacity on macOS.
Kiwi Des
Post by Kiwi Des » Mon Feb 01, 2021 3:23 am
Mac Big Sur Audacity 2.4.2
I am copying my record collection to my Mac mini. I copy the first side of my LP record with Audacity and export multiple to a folder, without problems.
the tracks will copy with serial number 01, 02, 03 etc.
Then when I copy and export multiple of the second side of the record Audacity starts the serial number count again from 01 which I then go through the folder files and manually amend to keep the album track sequencing correct.
Is there anyway of getting Audacity to begin serial numbering from a specific inputted value?
Hope this makes sense, thanks and regards Des
Re: LP side two track numbering to follow from side one
Post by steve » Mon Feb 01, 2021 10:24 am
The easiest solution is to name one of the exports "album-name Side 1 - <track number>" and the other "album-name Side 2 - <track number>", then it doesn't matter that both start numbering from 1.
