No devices showing up
Kc5f
Post by Kc5f » Sun Jan 31, 2021 12:29 am
For some reason every box is blank, whenever I try to record I get
Error code: 0 sucess
Re: No devices showing up
Post by kozikowski » Sun Jan 31, 2021 3:39 pm
Audacity gets its sound from Windows, not the device.
Open Windows control panels (Right-click the speaker symbol in the right) and see if your device appears there. Those panels also have a sound meter, so you can check everything.
Without that appearance and the bouncing sound meter, Audacity won't do anything.
There are some oddities. I think Windows still calls everything a "microphone" no matter what it really is, and it's complicated by the actual device name which has little or nothing to do with what it actually is.
For example, the Behringer UCA-202 stereo adapter is called a "microphone" and it's name is USB audio CODEC
jademan
Forum Crew
Post by jademan » Mon Feb 01, 2021 1:10 pm
Also, when Audacity first starts up. It scans every device on your system. If it hangs up on any one of those devices, it can cause Audacity to see nothing. If your issue continues, try removing or disabling all USB and bluetooth devices. If this fixes the problem, you can re-enable them one-by-one.
I hope this helps. :D
