extremely inefficient when installed on laptop
niobium
Post by niobium » Wed Jan 27, 2021 6:03 am
I installed audaciity 2.4.2 on a new laptop
HP, windows 10 home.
HP Laptop 14s-dk0xxx
AMD ryzen 5 3500U 2.1Ghz
8GB RAM 5.92 usable
64 bit operating system x64 based processor
when using it on this laptop , it usually goes into a (not responding) state after a single click of the play button and takes several minutes to start playing at all. sometimes, itwill only reply with a message telling me to try a new device or change the sample rate or something like that. I really need help with this, as it makes my work almost impossible to complete unless i switch back to an older laptop with a bad battery.
Re: extremely inefficient when installed on laptop
Post by steve » Wed Jan 27, 2021 10:27 am
What security apps are running? It's possible that a security app may be repeatedly scanning, or sandboxing Audacity.
What other apps are running (of any kind)?
niobium
Post by niobium » Fri Jan 29, 2021 11:49 am
are you sure security apps are disrupting it? i dont have much other installed anyway, other than mcafee, GOG, and a few webbrowsers. it also does not seem to make a difference if i access the files from a portable hard drive or on the laptops harddrive.
Post by steve » Fri Jan 29, 2021 12:59 pm
No I'm not sure, but it certainly sounds like something on that laptop is interfering with Audacity.
McAfee can be quite aggressive, and in the past we have heard reports of it interfering with Audacity.
I'd suggest that you try:
1. Reboot the computer
2. Disconnect from the Internet.
3. Turn off McAfee
4. Try running Audacity.
After testing, re-enable McAffee before re-enabling your internet connection.
Any difference?
waxcylinder
Post by waxcylinder » Fri Jan 29, 2021 1:21 pm
I've had McAfee running on all the various PCs and the one Mac that I have, or have had, over the past 15 years of using Audacity and it has never "interfered".
Peter.
jademan
Forum Crew
Post by jademan » Sat Jan 30, 2021 12:53 pm
Did you say what device it is that you are using :?:
niobium
Post by niobium » Sat Feb 06, 2021 5:46 am
yes, all the hardware specifics are listed in the first post. This problem might be something to do with soundcard drivers since it also seems to affect wavepad
Post by steve » Sat Feb 06, 2021 2:11 pm
That sounds possible.
If you're using the HP's built-in sound card, check on the HP website that you have the latest drivers for Windows 10.
(See: https://support.hp.com/gb-en/drivers)
niobium
Post by niobium » Wed Feb 17, 2021 11:01 pm
you were absolutely right about the soundcard drivers! after directly accessing the system tools and right clicking to have them update all drivers, it suddenly works like a charm. there were also other problems such as youtube videos pausing for a very long time and other applications that use sound malfunctioning.
