Recording cursor stuck
Hi all, I have a problem with the recording cursor being “stuck” and won’t move when I press record. I’m not sure what really changed because it was working fine a couple months ago. I’ve tried using all the info that I was able to dig up online like change the settings, the microphone privacy settings, rescan device and so forth. I did even fix it once but then I couldn’t hear anything through my headphones connected to my interface. Then when I fixed that, the recording problem still persisted and I’ve been stuck in this loop for a while now so any help would be greatly appreciated ! I believe I’m on windows 10 with a Rode NT4 mic and Rode A1-1 interface.
Re: Recording cursor stuck
See this topic: viewtopic.php?f=46&t=115379
