Cannot access "Preferences-Devices" to set Latency
Help for Audacity on macOS.
Beaudy
Post by Beaudy » Sun Jan 24, 2021 8:18 pm
Hi I am new here and to Audacity. I have read the manual and seen tutorials on how to set the Latency correction. I have gotten almost all the way there, however when I go to "Edit" to access the "Perferences-Devices" tab, there is no option under 'edit" for "Preferences" so I am stuck.
I'm using Mac OS 10.15.7 and Audacity 2.4.2. Any help would be greatly appreciated. Thanks in advance.
Re: Cannot access "Preferences-Devices" to set Latency
Post by steve » Sun Jan 24, 2021 8:26 pm
On a Mac, Preferences is under the "Audacity" Menu.
Beaudy
Post by Beaudy » Sun Jan 24, 2021 11:37 pm
Thanks, but that is exactly the problem...there is no "Preferences" choice in the Audacity "Edit" dropdown menu on my copy of it anyway.???
Very frustrating.
Post by steve » Sun Jan 24, 2021 11:44 pm
Not the "Edit" menu, the "Audacity" menu (first menu after the apple).
On macOS, that's the standard place for an app's "Preferences".
