RECORDING CUTS OFF AFTER 5 SECONDS
Help for Audacity on macOS.
kiw1217
Post by kiw1217 » Sat Jan 23, 2021 9:11 pm
I'm using macOS Catalina 10.15.7 and Audacity 2.4.2
My recording cuts off at exactly 5 seconds every time I try to record with no explanation - see attached.
(The 5 seconds it does record sounds perfect!)
Re: RECORDING CUTS OFF AFTER 5 SECONDS
Post by steve » Mon Jan 25, 2021 11:14 am
Do you literally mean: Exactly 5.000 seconds?
jademan
Forum Crew
Post by jademan » Tue Jan 26, 2021 4:52 pm
What does Allen & Heath have to say?
Have you tried recording with QuickTime?
kiw1217
Post by kiw1217 » Wed Jan 27, 2021 4:02 pm
Yeah literally 5.000 seconds every time
Post by steve » Wed Jan 27, 2021 5:20 pm
Do you have any trial / demo plug-ins installed?
Does your Mac have a built in mic? If it does, try recording from the mic to see if the same thing happens.
