Aud. 2.3.2
I'm getting an annoying click/pop sound when I join 2 split clips on a track. The black line that divides/joins them is where I keep hearing it. I don't recall it doing that before. How to get rid of that?
Annoying Pop sound between 2 tracks
Rickenbacker
Re: Annoying Pop sound between 2 tracks
A crossfade will probably fix it, no matter what the cause. The crossfade can be very short (several milliseconds) if you don't what to hear it as a crossfade.
It could be caused by a DC offset (usually the result of a hardware problem) or it could be from not cutting on a zero crossing.
