Build aup from file list, timecode and label list via command line
Help for Audacity on macOS.
victorj255
Post by victorj255 » Sat Jan 23, 2021 7:22 am
Not sure if this is in the documentation but wondering if there is a way to script adding hundreds of small audio files programmatically to an audacity timeline / wave track at a specific start points and do the same for labels. Tried generating an aup file's xml but no success substituting .mp3 or .aiffs for .au files.
Re: Build aup from file list, timecode and label list via command line
Post by steve » Sat Jan 23, 2021 12:33 pm
Yes, you could do that with Python. See: https://manual.audacityteam.org/man/scripting.html
