Building a small wxWidgets library (linux)
Building and customizing Audacity from the source code.
maabaum
Operating System: OS X 10.6 Snow Leopard or earlier
Post by maabaum » Fri Jan 22, 2021 8:22 pm
Has anyone worked out a definitive list of the feature options that can be safely disabled in the Audacity-modified wxWidgets 3.1.3 libraries? In a mood of idle curiosity, I tried to compile a minimalist version using the suggested list of unnecessary features given in the instruction document: wxWidgets/docs/gtk/install.md . In retrospect, this might have been naive.
In any event, the make process rapidly blows up due to a variety of unmet requirements apparently set elsewhere in the config files, things like wxUSE_MIMETYPE, wxJoystick, wxUSE_SVG, usw. I had kind of thought the install.md document might have been specifically tailored for building wxWidgets for use with Audacity, but maybe it's an artifact from earlier times.
Anyway, I wondered if anyone had ever worked out the minimal configuration for use with Audacity.
I was building this under Fedora linux (33) if that matters.
tnx
Re: Building a small wxWidgets library (linux)
Post by steve » Sat Jan 23, 2021 3:23 pm
Audacity needs:
libwx_baseu-3.1.so
libwx_baseu_net-3.1.so
libwx_baseu_xml-3.1.so
libwx_gtk2u_core-3.1.so
libwx_gtk2u_html-3.1.so
libwx_gtk2u_qa-3.1.so
suil_x11.so
suil_x11_in_gtk2.so
suil_x11_in_gtk3.so
The total size of these shared object files is about 14.3 MB.
These are built automatically when Audacity is configured with:
Code: Select all
-Daudacity_use_wxwidgets=local
On Ubuntu 18.04, I generally build Audacity with:
Code: Select all
cmake -DCMAKE_BUILD_TYPE=Release -Daudacity_use_ffmpeg=loaded -Daudacity_use_wxwidgets=local ..
make -j8
or for a debug build:
Code: Select all
cmake -DCMAKE_BUILD_TYPE=Debug -Daudacity_use_ffmpeg=loaded -Daudacity_use_wxwidgets=local ..
make -j8
