No option of 2(stereo) recording
Help for Audacity on macOS.
SparklingWaters
Post by SparklingWaters » Fri Jan 22, 2021 12:34 pm
I have just installed Audacity 2.4.2 on my new MacBook macOS Big Sur v. 11.0 and no longer have the option of stereo (2) recording on the drop down bar - just the 1 mono option. This means I can't record two tracks and then work on them separately. Any suggestions most welcome... Thanks
Re: No option of 2(stereo) recording
Post by steve » Fri Jan 22, 2021 12:39 pm
What is your recording device?
jademan
Forum Crew
Post by jademan » Sat Jan 23, 2021 1:56 pm
So, as steve indicated, the number of channels you can record depends on the device you are recording from. A microphone normally will only produce one channel (mono). (Then again, I am a Windows guy and there may be another trick on MacOS).
If you need two tracks from a mono source, after recording, you can select the track, then Edit>Duplicate, or Ctrl-D (on WIndows), for short. To make stereo, click the drop-down on the top Track Control Panel, then select Make Stereo Track.
I hope this helps. :D
