Help for Audacity on macOS.
Audacity 1.2.x and 1.3.x are obsolete and no longer supported. If you still have those versions, please upgrade at
https://www.audacityteam.org/download/.
The old forums for those versions are now closed, but you can still read the archives of the
1.2.x and
1.3.x forums.
Nesilica2
Post
by Nesilica2 » Thu Jan 21, 2021 3:56 pm
Hi,
does anyone knows how to fix this?
I downloaded the plugin from wikipedia and placed it into audacity plugin folder
after I click on "add extension" it gives me the error can't open the file
I'm using MacOS Catalina 10.15.6 (19G73)
Audacity: 2.3.3
Thank you!
Nesilica2
Post
by Nesilica2 » Thu Jan 21, 2021 7:52 pm
yes, that's exactley what I meant. Thank you
will update it
Nesilica2
Post
by Nesilica2 » Sat Jan 23, 2021 1:24 pm
Mission completed! 2.4.2 is on.
but I have another question now - what would you say is the (main) difference between noise gate and the typical noise reduction option(i have it in german so I don't know how it is called in english )
becuase it seems to me that they are super similar.
Thank you
- Site Admin
Post
by steve » Sat Jan 23, 2021 1:42 pm
The "
Noise Reduction" effect looks for frequencies that are in the "noise profile", and reduces those frequencies when they are below a specified level.
The "
Noise Gate" does not use a "profile". It acts on all frequencies whenever the audio level goes below the threshold level.
Nesilica2
Post
by Nesilica2 » Sat Jan 23, 2021 3:57 pm
ohhhh I see!!
Thank you so much for clarifying it
