MP3 import stopped working!!!
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 3:44 pm
Hi, first post. I've been editing our podcasts for a year and all of a sudden the first podcasts of 2021 and I can't get the music (mp3) files to load into audacity. I've tried reloading the Lame and FFMpeg libraries and nothing. HELP!!!
DVDdoug
Forum Crew
Re: MP3 import stopped working!!!
Post by DVDdoug » Thu Jan 21, 2021 4:07 pm
There was a change that makes Audacity more picky about imperfect MP3s... They fixed one problem but then it turned-out that there are lots of "invalid" (but still working) MP3s floating-around....
Until that's "corrected" there is a work-around using FFmpeg.
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 5:24 pm
Awesome!!! Many, many, thanks! I was going crazy!! :)
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 7:02 pm
Uh OH! Now I can't upload MP4 files like I used to. I get a different error now. Is there another rule I need to make that work now?
Post by steve » Thu Jan 21, 2021 7:10 pm
"Upload"?
Do you mean "Import" into Audacity, or "Export" from Audacity, or something else?
What is the full and complete error message?
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 7:16 pm
Sorry, normally I drag and drop my raw mp4 files into audacity. Now I get an error stating that it's "an advanced audio coding file. Without the optional FFMpeg library, audacity can not open this type of file.
Post by steve » Thu Jan 21, 2021 7:35 pm
Look in "Edit menu > Preferences > Libraries".
Which version of FFmpeg does it say you have?
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 7:37 pm
Lame MP3 Export Library version: 3.1 (built-in)
Post by steve » Thu Jan 21, 2021 7:56 pm
Please try this:
1. Exit Audacity
2. Restart Audacity
3. "Help menu > Diagnostics > Show Log"
4. Copy and paste the contents of the log into your reply.
Siggy62
Post by Siggy62 » Thu Jan 21, 2021 7:58 pm
13:57:23: Audacity 2.4.2
13:57:23: Trying to load FFmpeg libraries...
13:57:23: mLibAVFormatPath ('C:\Users\Signol\Documents\Applications\Lame_v3.99.3_for_Windows.exe') is not empty. Loading from it.
13:57:23: Looking up PATH environment variable...
13:57:23: PATH = 'C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\Signol\AppData\Local\Microsoft\WindowsApps;'
13:57:23: Checking that 'C:\Users\Signol\Documents\Applications' is in PATH...
13:57:23: Warning: FFmpeg directory 'C:\Users\Signol\Documents\Applications' is not in PATH.
13:57:23: Temporarily prepending ';C:\Users\Signol\Documents\Applications' to PATH...
13:57:23: Checking for monolithic avformat from 'C:\Users\Signol\Documents\Applications\Lame_v3.99.3_for_Windows.exe'.
13:57:23: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 127: The specified procedure could not be found.)
13:57:23: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 127: The specified procedure could not be found.)
13:57:23: avformat not monolithic
13:57:23: Loading avutil from 'avutil-52.dll'.
13:57:23: Error: Failed to load shared library 'avutil-52.dll' (error 126: The specified module could not be found.)
13:57:23: Loading avcodec from 'avcodec-55.dll'.
13:57:23: Error: Failed to load shared library 'avcodec-55.dll' (error 126: The specified module could not be found.)
13:57:23: Loading avformat from 'C:\Users\Signol\Documents\Applications\Lame_v3.99.3_for_Windows.exe'.
13:57:23: Returning PATH to previous setting...
13:57:23: Error: Couldn't find symbol 'avutil_version' in a dynamic library (error 126: The specified module could not be found.)
13:57:23: Actual avutil path
13:57:23: Error: Couldn't find symbol 'avcodec_version' in a dynamic library (error 87: The parameter is incorrect.)
13:57:23: Actual avcodec path
13:57:23: Error: Couldn't find symbol 'avformat_version' in a dynamic library (error 127: The specified procedure could not be found.)
13:57:23: Actual avformat path
13:57:23: Importing symbols...
13:57:23: Error: Failed to load symbol av_register_all
13:57:23: Trying to load FFmpeg libraries from system paths. File name is 'avformat-55.dll'.
13:57:23: PATH = 'C:\Users\Signol\Documents\Applications;C:\Program Files (x86)\Common Files\Oracle\Java\javapath;C:\windows\system32;C:\windows;C:\windows\System32\Wbem;C:\windows\System32\WindowsPowerShell\v1.0\;C:\windows\System32\OpenSSH\;C:\Program Files (x86)\NVIDIA Corporation\PhysX\Common;C:\Users\Signol\AppData\Local\Microsoft\WindowsApps'
13:57:23: Checking that '' is in PATH...
13:57:23: FFmpeg directory is in PATH.
13:57:23: Checking for monolithic avformat from 'avformat-55.dll'.
13:57:23: Error: Failed to load shared library 'avformat-55.dll' (error 126: The specified module could not be found.)
13:57:23: Loading avutil from ''.
13:57:23: Error: Failed to load shared library '.dll' (error 126: The specified module could not be found.)
13:57:23: Loading avcodec from ''.
13:57:23: Loading avformat from 'avformat-55.dll'.
13:57:23: Error: Failed to load FFmpeg libraries.
13:57:23: Error: Failed to find compatible FFmpeg libraries.
