Windows 10 - Audacity 2.4.2
I uninstalled audacity Yesterday, Today I installed it again.
I found this warning message (in the attached screenshot), and the program failed to open!
Any help please
Error opening Audacity
Salma Hamdy
- Attachments
- 2021-01-20 (2).png (8.36 KiB) Viewed 93 times
Re: Error opening Audacity
Audacity 2.4.2 on Windows is a 32-bit program. This error can occur, for example, if you are trying to run a 64-bit plugin with a 32-bit Windows. You will need to install a 32-bit version of Leslie. See: https://manual.audacityteam.org/man/ins ... ndows.htmlSalma Hamdy wrote: ↑Wed Jan 20, 2021 10:38 pmI found this warning message (in the attached screenshot), and the program failed to open!
Any help please
To remove the old version of Leslie from your menu, you can locate your plugin under Tools>Add/Remove Plugins.., click Disable, and OK, then remove it from your plugins folder.
I hope this helps.
