Time-Shifting Multiple Tracks
LesPaul75
Post by LesPaul75 » Sat Jul 18, 2009 4:22 am
The Audacity Wiki says this:
To time-shift multiple clips at once, select all of the clips you want to move using the normal selection tool, then use the time-shift tool to click and drag. If you click within the selection, all selected clips will move together. If you click outside the selection, only the clip under the mouse cursor will move.
This does not work for me in Audacity 1.2.6. It shifts only the track that is clicked, regardless of whether I click within the selection or outside it.
Re: Time-Shifting Multiple Tracks
Post by steve » Sat Jul 18, 2009 1:04 pm
Upgrade to Audacity 1.3.8
