I am recording on a brand new PC laptop, after replacing my 9 year old Mac, and when I only record on a single track everything is fine. However, when I add a track and attempt to record audacity SAYS it’s recording, but it isn’t. I’ve attached a screenshot as well. If I change either the output or the input to computer speakers/microphone it will allow me to record, but that defeats the purpose of having a studio. I have quality cables plugged into the USB 3.0, so I’m pretty sure it’s not an output issue, as the old Mac could handle the output no problem. Is there something I’m missing? I’m pretty illiterate when it comes to Windows, but I’m learning, and any help would be greatly appreciated!
Thanks!
Audacity won’t record when adding new tracks.
- Attachments
- Attempting to record on lower track. Audacity says it’s recording, but it’s not.
- B0D4DF41-CB19-411F-95EB-C92BC2D8F356.png (268.12 KiB) Viewed 223 times
Re: Audacity won’t record when adding new tracks.
Have you tried it with Ableton Live Lite to see if the problem occurs there too?
So in the lower left-hand corner of the screen you will see your Project Rate: 44100. Right-click on your speaker icon then Sounds>Recording>[Rode AI-1 USB]>Properties>Advanced>Default Format. Change this to 44100 to agree with Audacity. Or set both to 48000. Also check the same for Sounds>Playback.
I hope this helps.
That did the trick! Thank you so much!!!!
