Just to say hello
davday
Re: Just to say hello
Post by davday » Fri Feb 19, 2021 6:12 pm
Re Mic wont work..
Thanks to steve for mentioning the search box, and thanks to jademan for direction to the magnifying glass
to look for, all is back working again , thank you both for your input. davday
