Audio preview of edit
Help for Audacity on macOS.
Gregg Borschmann
Post by Gregg Borschmann » Thu Jan 14, 2021 5:00 am
Is there a shortcut for hearing an audio preview of a proposed edit or before cutting or deleting the unwanted audio?
I am working with simple two-track oral history recordings.
Using Audacity 2.3.3 and Mac High Sierra.
Gregg Borschmann
Writer & Oral Historian
Australia
Re: Audio preview of edit
Post by steve » Thu Jan 14, 2021 10:25 am
"C" (Play Cut Preview)
Plays audio excluding the selection. The amount of audio that is played before and after the section is set by the Cut Preview setting in Playback Preferences.
See: https://manual.audacityteam.org/man/ext ... ut_preview
jademan
Forum Crew
Post by jademan » Fri Jan 15, 2021 5:53 pm
... and, as you know, there are an unlimited number of undo's allowed.
