Poping/Static - not my equipment?
DVDdoug
Forum Crew
Re: Poping/Static - not my equipment?
Post by DVDdoug » Sat Jan 16, 2021 1:15 am
same Mhz sample rate at 48000
That's 48kHz or 48,000Hz. ;)
Post by kozikowski » Sat Jan 16, 2021 2:38 am
Referencing the Sampling Monster Under the Bed is fun and all, but we need to find another reason. That's my UM2.
22050SamplingRate.wav
(595.62 KiB) Downloaded 9 times
32000SamplingRate.wav
(539.91 KiB) Downloaded 10 times
44100SamplingRate.wav
(1012.04 KiB) Downloaded 8 times
48000SamplingRate.wav
(701 KiB) Downloaded 8 times
Post by kozikowski » Sat Jan 16, 2021 2:56 am
As a fuzzy overview, your machine is taking a coffee break every so often and leaving holes in your show.
Mess with the machine. Make it better or worse. If you can reliably change the damage, it will be a big help.
Busy out the machine. Open up a bunch of applications and see what happens. Make a recording while you're listening to a YouTube presentation.
Disconnect the network. No wires, no WiFi. Try that. This one's my bet. You're going to disconnect the internet and something least expected is going to scream at you.
Post by kozikowski » Sat Jan 16, 2021 3:23 am
This one's my bet.
Go to Control Panel/Network and Sharing Center and from the left hand window open the Network Adapter Settings. And chose your connection to which you are connected, open it and there you'll see its properties and status. Click on “Disable” to make it disable. Now your System will be disabled from Internet Access.Dec 2, 2020
From the Windows desktop, click the Wi-Fi icon. (located in the lower-right, in the task bar). ...
From the Wi-Fi section (on the right, above the task bar), click the connected Wi-Fi network address.
Click Disconnect.
