Sony SoundForge's Smooth Preset Wave Hammer equivalent in Audacity?
Ranx
Operating System: macOS 10.11 El Capitan
Post by Ranx » Wed Jan 13, 2021 10:24 pm
Greetings all...
I'm trying to learn how to use Audacity as a replacement to Sony SoundForge, or at least the few regular functions I use frequently when mastering live shows to release as podcasts.
All I ever tend to do to a raw WAV or AIF of a live session is the following steps in this order, and I'd be very grateful if you could help me find the equivalent features (if they exist, or whatever would achieve the closest result) in Audacity.
1. Place markers at the exact start and finish of the section of the audio I want to keep (before deleting the excess to leave just the show and none of the set up soundchecks or crowd leaving the venue).
2. Normalize left channel.
3. Normalize right channel.
4. Select all audio (both channels) and apply Wave Hammer using presets Smooth or Medium (so the audio is boosted to nice and loud levels for listening back on car stereos or personal stereos, so that quieter dialogue or music parts are nearer the volume of the loudest parts) and the waveform looks more consistently the same level throughout.
5. Normalize both channels together.
6. Apply five-second fade-in at the start.
7. Apply five-second fade-out at the end.
- occassionally I need to place multiple markers throughout the entire recording and delete portions in between those markers, such as for songs I don't have the rights to release yet which were featured within the show. I there a way to do this too?
Thank you very much for your help, and big thanks to all the developers for giving us a free SoundForge equivalent.
I hope to hear from you soon.
Re: Sony SoundForge's Smooth Preset Wave Hammer equivalent in Audacity?
Post by steve » Wed Jan 13, 2021 10:52 pm
Select the audio that you wish to retain,
then "Edit menu > Remove Special > Trim Audio" (or "Ctrl + T") https://manual.audacityteam.org/man/edi ... ecial.html
https://manual.audacityteam.org/man/normalize.html
Select the first 5 seconds of audio,
then apply "Fade In" effect.
https://manual.audacityteam.org/man/fad ... linearfade
More complex fade types may be applied with the "Adjustable Fade" effect: https://manual.audacityteam.org/man/adj ... _fade.html
Select the final 5 seconds of audio,
then apply "Fade Out" effect.
Alternatively you could use the "Studio Fade Out" effect (https://manual.audacityteam.org/man/fad ... io_fadeout)
or "Adjustable Fade".
Sounds like a job for "Labels": https://manual.audacityteam.org/man/label_tracks.html
Label the parts that you wish to delete (with "Region Labels") then,
"Edit Menu > Labeled Audio > Delete"
Post by steve » Wed Jan 13, 2021 10:54 pm
What is "Wave Hammer"?
If it's a "limiter", then: https://manual.audacityteam.org/man/limiter.html
If it's a compressor, then there's https://manual.audacityteam.org/man/compressor.html
though you will probably find a better compressor as a VST effect (see: https://manual.audacityteam.org/man/ins ... ndows.html)
