Error Importing on 2.4.2 version
Hey everyone...trying to load a saved project into Audacity and this is the msg that pops up..."C:\Users B-Roll\Documents\Audacity\(name of the file)" is an Audacity Project File. Use the 'File>Open' command to open Audacity Projects...I am using 'File>Open' as I do with every saved project. I've yet to encounter this issue with any other saved project and I checked several of them to make sure it wasn't an issue and, they all open normally...PLEASE help! Why won't this particular file open??
Re: Error Importing on 2.4.2 version
What is the file extension of "name of the file"?
The entire error importing msg reads..."C:\Users\McAllister B-Roll\Documents\Audacity\EP_9.aup" is an Audacity Project file. Use the 'File > Open' command to open Audacity Projects...which I have. That's how I open every saved project.
Thanks.
Thanks.
Please attach the "EP_9.aup" file to your reply (See: viewtopic.php?f=49&t=64936)
I suspect the file is corrupt, which is something that I can check very easily.
Here you go...Thanks for the effort!
- Attachments
- EP_9.aup.aup
- (89.02 KiB) Downloaded 15 times
As I suspected, that file is (totally) corrupted.
Is it possible that project could have been created with Audacity 2.2.1?
Yes, I believe that was the version. I downloaded 2.4.2 after it was recommended I update.
There was a bug in the 2.2.1 version. If "Save As" was used to update the current project (rather than just using "Save" or "Ctrl + S"), the project was corrupted. I suspect that's what happened with that project.
Argh!! So, she's a goner? In the future, use 'Save' instead of 'Save As'?
Unfortunately yes.
It doesn't matter so much now because the bug has been fixed, but normally you would use "Save" unless you wish to save the project with a different name or different location.
Example 1:
Saving a new project that hasn't previously been saved:
"File menu > Save Project > Save Project (Ctrl + S)"
You will be prompted to specify a name and where to save it.
Example 2:
Saving a project that has been previously saved:
The saved project is updated.
Example 3:
Saving an existing project with a new name:
"File menu > Save Project > Save Project As..."
You will be prompted to specify a new name for the project and where to save it.
